What top tranny mount do i need to put b-series in automatic 93?
I have a automatic 93 coupe and im putting a 94 gsr swap into it. I will be converting it manual. Since the car is an automatic im not sure what tranny mount i need. Info i found says to keep the top tranny mount from the civic, it will work on b-series tranny.
SO do i need the tranny mount from a manual civic? and if so will it work right on the auto car? thanks
Re: What top tranny mount do i need to put b-series in automatic 93? (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">yes you need the mount from a manuel civic like you said. the chasis is the same regardless of manuel or auto.</TD></TR></TABLE>
Actually, I believe you are wrong, the chassis does differ from auto to manual. The bracket is in a different location. Hasport sells a mount that allows you to use a 5sp trans in an automatic chassis. The rear and left hand mount will still work just fine.
cloud4571
09-29-2012 03:25 PM
turboblack2door
06-08-2011 02:50 PM
Si Integra
03-09-2005 12:38 PM
