what size are the front license plate bolts 00 si?
anyone know the proper sized bolts for the front license plate on an 00 si? Po-po just gave me a ticket for no front plate and I've tried like 10 different bolts with no luck so far. Are they some fucked up size I'm going to have to get straight from the dealer or what?
Re: what size are the front license plate bolts 00 si? (SFC)
they should be a standard 10mm head bolt. Same size bolt that holds most of the car together. Same size bolt the rear plate uses. Hope that helps.
Re: what size are the front license plate bolts 00 si? (upgraded)
my fronts are different than my rears... I don't think it's an aftermarket front end, it looks like all other si's, though I suppose it could be. I pulled the rear bolts to try on the front and they didn't fit :/
Re: (SFC)
they should just be standard 10mm bolts. The rear license plate should have worked. Go to your local Lowes to get some bolts. Is the 10mm too big or small?
Re: (SFC)
10mm, make sure the bolt is going in completly straight. Also, the part the bolt threads into will fall out of the bumper if you push too hard
OogalyDoogaly
06-14-2007 04:06 PM
