what should i expect to break at 500hp??
i have a 2000 civic si coming out of the shop soon and its going to have close to 500hp at the wheels.i have a 3 point password jdm strut bar,im still using the stock motor mounts,i have stage 5 axles from driveshaftshop and a brand new tranny.can you guys tell me what i should expect to break from here if im going to be drag racing and what else i should get to prevent anything from happening?
thanx for your help
thanx for your help
Re: what should i expect to break at 500hp?? (Luserkid)
I would think your mounts are going to get trashed before long, a good set of mounts will help prevent a lot of other stuff from getting trashed as well.
if your Si is like mine, expect every little god damn piece of **** to break... it's just how it works, the little things are the ones that **** you off to, good luck, that power is fun.
been there done that
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zboog929 »</TD></TR><TR><TD CLASS="quote">i have a 2000 civic si coming out of the shop soon and its going to have close to 500hp at the wheels.i have a 3 point password jdm strut bar,im still using the stock motor mounts,i have stage 5 axles from driveshaftshop and a brand new tranny.can you guys tell me what i should expect to break from here if im going to be drag racing and what else i should get to prevent anything from happening?
thanx for your help</TD></TR></TABLE>
what kind of clutch? what kind of build does the engine have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">with that much power don't most tracks require a roll cage?
or is that depending on the location.
depends on et's and/or mph
Did you get limited slip put on the tranny? I wouldnt put an open diff. tranny on there with that much power just cuz you spent all that money and wont even utilize all of the power. What mods/internals are you running?
Re: (nix94delsol)
The motor mounts woun't hold for long at those power levels. traction bars or not. I would upgrade those. Otherwise be carefull about dumping the clutch and preloading and you should be pretty good.
Re: (Hittnthebz)
I WENT WITH A GSR BLOCK WITH
CP PISTONS AND RINGS
EAGLE RODS
BLOCK GUARD
STOCK GSR CRANK
RC 720CC INJECTORS
VORTECH FUEL RISER
FUEL RAIL,REGUALTOR LINES AND FITTINGS
POWER FC COMMANDER
TURBONECTICS T62 TWIN SCROLL
FULL RACE HEADER
EDLEBROCK INTAKE MANIFOLD
GREDDY OIL COOLER
IM RUNNING A LS TRANNY WITH A CARBON PLATE LSD AND A STAGE 5 ACT CLUTCH
I WAS TOLD THAT WITH HASPORT MOTOR MOUNTS ITS GOING TO GIVE THE CAR A ANNOYING VIBRATION,IS THAT TRUE? HOW LONG WILL THE STOCK MOTOR MOUNTS HOLD FOR AND ARE THEY EASY TO INSTALL?
EAGLE RODS
BLOCK GUARD
STOCK GSR CRANK
RC 720CC INJECTORS
VORTECH FUEL RISER
POWER FC COMMANDER
FULL RACE HEADER
GREDDY OIL COOLER
Re: what should i expect to break at 500hp?? (zboog929)
Others might tell you a stock transmission is okay, perhaps cryo-treat the internals or upgrade the synchronizers. But understand that I'm an overkill kind of guy, so to be safe than sorry I would recommend a conversion to a dog ring transmission with straight cut gears. Also, I'm assuming that if you're like most people, your power will continue to increase.
Re: what should i expect to break at 500hp?? (Hardedge)
THANX FOR THE INFO,IM THINKING THE TRANNY SHOULD HOLD UP FOR A WHILE,IM PROB GOING TO PLAN ON BUILDING ONE SO IT CAN BE BULLET PROOF.....AND 500HP SHOULD BE ENOUGH FOR NOW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardedge »</TD></TR><TR><TD CLASS="quote">Others might tell you a stock transmission is okay, perhaps cryo-treat the internals or upgrade the synchronizers. But understand that I'm an overkill kind of guy, so to be safe than sorry I would recommend a conversion to a dog ring transmission with straight cut gears. Also, I'm assuming that if you're like most people, your power will continue to increase.</TD></TR></TABLE>
so basically you want him to convert to a race only tranny?
Re: (zboog929)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zboog929 »</TD></TR><TR><TD CLASS="quote">I FORGOT TO MENTION GSR TYPE R CAMS </TD></TR></TABLE>
based on this quote i wouldnt take his claimed 500 hp seriously...
Re: (tha_badguy)
your not gonna break a honda trans (if its in good condition to begin with) i know people with 300-500+ whp hondas and their trans dont break.... whipfactory uses factory trannys on all their cars cause their reliable.. the ek they got has a type r and nothings broken.. their old eg (my hatch) had a stock trans (3rd stg of boost at 650whp) and it never broke.. dont worry about your trans worry about your motor mounts... grab a set of avid either street/strip or race mounts (i went with race and im gonna be at 550+ on my 3rd stg of boost) you wont break those
Re: what should i expect to break at 500hp?? (kseriesFTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kseriesFTW »</TD></TR><TR><TD CLASS="quote">500 hp on a stock tranny doesnt sound like a good ending to me... i could be wrong tho..</TD></TR></TABLE>
yeah .. you are
yeah .. you are
