What is normal engine noise for a b16a2?
Video posted below is a stock b16a2 with 150k miles on it. I've actually never hear another stock on and have no reference for how this motor should sound. Is it ticking/knocking to much? Is this totally normal? And for anyone on here who have never hear a b16 that didn't have an intake/header/exhaust, here you go! Your thoughts are welcome!
Re: What is normal engine noise for a b16a2?
Honestly, B16s are just noisy engines even when they were brand new. I've had quite a few of them and have simply gotten used to the rattly/ticky noise they make. My current swap is a B16A2 from a 2000 Si that had 80k on it. Before the swap, I changed all the gaskets, belts, hoses, did a valve adjustment and put now change the oil every ~2k miles. Compression and everything else on this motor are right in spec and it still sounds like this. So long as you don't hear any rod knock and your valves are adjusted correctly, the next step would be swapping out the LMAs. It might help a little, but don't expect a B16A to be super quite.
I've heard the b series are just noisy in general. After listening to the video what are your thoughts? Regular amount of tick/noise? I've never heard and serious knocking but I do hear a more constant whirring noise that is rev dependent. I'm not sure if it is the engine or trans or maybe even the alternator.
Azxster
09-28-2007 08:16 PM
