What linkage can I use
Re: What linkage can I use (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Why would it be "backwards"? JDM cars use the same shift pattern. </TD></TR></TABLE>
The shift pattern's exactly the same as it is on UDSM or EDM cars.
It's not different.
With your JDM GSR you can use either a JDM shift linkage or a USDM shift linkage - both will fit.
It's not different.
Re: What linkage can I use (Petey Puff)
Then I don't have a clue what I was sent with this swap. The 2 bars do not fit. thanks for the help. Also how do I become a member to this forum? I have been using this site for info forever.
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petey Puff »</TD></TR><TR><TD CLASS="quote">Noob is a member?</TD></TR></TABLE>
You're an unrestricted normal member. As for the linkages not reaching, I really can't offer an explanation, since they should work fine.
