what K are these HID's
I remember that car in a thread with other pics of it. The lights are some kind of yellow HID. I can't remember the name, but I know the guy wanted to be different as far as the lights. I personally like the OEM HID on the 350
Re: (Hybrid93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">They are actually 12,000kilowatt HID's and they're retardedly expensive AND illegal . They're the hotness though .</TD></TR></TABLE>
yeah i'd say theyre high up on the spectrum too
Re: (J-Unit.com)
i dont have the link, but you should see the turbos + intercooler + pistons and rods that dude has got for the turbo set up :drool:
Re: (Archidictus)
he has lasers for headlights!
Re: what K are these HID's (JSPECHB)
I'm running Sylvania SilverStar halogens (nice ) and those run at 4000K.
That is a very white bulb. Daylight is 5400K. With the yellow look of those, I'm going to say they're 3200-3500K.
Re: (Archidictus)
If you look at my above post, you'll see that 12,000K is...uhh...retarded. That's more than double the color temp of daylight.
Re: (Archidictus)
ummmm...do you mean 12,000kelvin (not kilowatt ) I thought they're like the LeMan's cars' HIDs I think the K was actually like 3500-3800 (close to the same color band as halogens) 12,000K(elvin) I thought was a rediculous blue/purple.
Re: (adirondackR)
This should shed a little light for everybody http://www.schorsch.com/kbase/glossary/cct.html
Re: (Crank)
I remember seeing a post on this same car (maybe in the appearance forum - where this post REALLY belongs)- he has got aftermarket "YELLOW" hids (like LeMans cars) - they don't come stock, so don't call nissian & ask
see
https://honda-tech.com/zerothread?id=646726 3100K HIDs
(sorry could find old post on the Z pictured)
see
Re: (B16SI00)
Alright, before posting bullshit do some research.
A. The 350Z comes w/ optional Xenon bulbs
B. Xenon (n.): A colorless, odorless, highly unreactive gaseous element found in minute quantities in the atmosphere, extracted commercially from liquefied air and used in stroboscopic, bactericidal, and laser-pumping lamps. Atomic number 54; atomic weight 131.29; melting point -111.9°C; boiling point -107.1°C; density (gas) 5.887 grams per liter; specific gravity (liquid) 3.52 (-109°C).
C.In the case of HID headlights, the same high-pressure technology is used. The lamp is similar to a mercury vapor lamp. However, designers of the headlights had to solve one problem with normal mercury vapor lamps -- the fact that they have long start-up times. Xenon helps solve the start-up problem, as does a special controller. All of these tricks mean that these headlights are expensive now, but mass production should bring the cost down eventually.
D. Stock xenons come in between 4000-4500k. The brightest aftermarket xenon I have been able to find is 5800k.
With that being said, I'm going to say those are halogens.
Re: (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">
ummmm...do you mean 12,000kelvin (not kilowatt ) I thought they're like the LeMan's cars' HIDs I think the K was actually like 3500-3800 (close to the same color band as halogens) 12,000K(elvin) I thought was a rediculous blue/purple.</TD></TR></TABLE>
12,000 kelvin would be pretty hot, kinda like the sun right?
Re: (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">
12,000 kelvin would be pretty hot, kinda like the sun right?</TD></TR></TABLE>
Read the thread, read the thread, then read it again! It's not a temperature of hot v. cold. It's color temperature.
I'll post this again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">I'm running Sylvania SilverStar halogens (nice ) and those run at 4000K.
That is a very white bulb. Daylight is 5400K. With the yellow look of those, I'm going to say they're 3200-3500K.</TD></TR></TABLE>
then this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">This should shed a little light for everybody http://www.schorsch.com/kbase/glossary/cct.html</TD></TR></TABLE>
then this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">Alright, before posting bullshit do some research.
With that being said, I'm going to say those are halogens.</TD></TR></TABLE>
READ, READ, READ!!!
then this
then this
READ, READ, READ!!!
Re: (JRI94)
hey JRI94 - read this again - i saw a post on this Z in the appearance forum - they are yellow HIDs NOT halogens anyways I am requesting this be moved to appearance/cosmetic forum as it has NOTHING to do with ek/eg/del sols
another thing to repeat the are NOT 12,000k - they most likely are 3,100k aftermarket HIDs - fuggin people have got to start READING the thread BEFORE they post -
