what gauge cluster to swap with?
Re: what gauge cluster to swap with? (DRAG14ciVHBKSI)
how much mileage do you have on your cluster? can i have it?
btw anyone know how to wire up an eg si cluster to an eg cx? just straight bolt in?
Re: what gauge cluster to swap with? (MnC CRX)
Any cluster off of a 5th Gen civic will bolt right in, no rewiring needed.
you can also wire up a cluster from 94+ integras to it with some rewiring and cutting. (you have to cut the sides of the cluster down to fit into the spot for the civic cluster) I did a GS-R cluster swap myself and I love it, there are a couple of other people here who've done it as well with pics and the such if you're interested
Re: what gauge cluster to swap with? (Extent)
cam i do this to my 99 ex?
I want to put in the 99-2001 gsr Cluster
do u know if i have to cut, rewire to get it in to place & working?
any sites?
[Modified by RataBlanca, 1:18 AM 8/24/2002]
any sites?
Hey Extent, you said you swapped an integ cluster into the civic? Can you tell me more about it? I'm interested in doing it. Do you have pix, or can you get some?
[Modified by daltonnnn, 6:23 PM 8/24/2002]
Re: what gauge cluster to swap with? (daltonnnn)
here's a link to a thread that happened a little while ago, it has some pictures and a little discussion
https://honda-tech.com/zerothread?id=240048
the only thing to really worry about is getting yourself the cluster side of the integra wiring harness, or else you'll have to solder directly onto the plastic backing of the cluster. Not fun, let me tell you.
The rest of the install, if you're reasonably handy with your tools is pretty easy, just cutting the cluster flush to the face plate, fitting it around inside the dash. you can use the screw holes that are already there but it will sit a bout a half inch too low. it's not to hard to get it up right tho.
I'll see if I can dig up the wiring diagram I was given, thats really the only other info you need...
Can you please? The last picture on that thread looked clean. So what exactly do I need to cut? And does the cluster really sit flush with the 5g black cluster?
