what exhaust to run with jrsc,header?
i have some ideas,but i want some feedback.i currently run a greedy sp,jdm header.im running a built gsr motor with a jrsc.....
Re: what exhaust to run with jrsc,header? (sloweg6)
Any header will do with forced induction, but how about the thermal research turbo cat-back? I think it's 3 in. diameter.
I had a JUN header with a greddy EVO exhaust and i didnt like it much the header couldnt hold the pressure and broke the welds, I am now running a Kamakazi header with dual apex-i n1 and i love it
Re: what exhaust to run with jrsc,header? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">i've heard kamikaze headers are good for supercharged applications. </TD></TR></TABLE>
same here
same here
Re: what exhaust to run with jrsc,header? (Spade)
Khamakazi loves the supercharger. a ton of people are running that and have had great results. not too sure exhaust wise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
same here</TD></TR></TABLE>
Yep, same here, plus they aren't too expensive...
'I can say that for blown Honda applications, of 7 psi and above, there's not any other header on the market that makes as much power. We use them personally and they go on all the engines equipped with our blower systems.
* Many people are under the impression that the primary tubes on Kamikaze headers are too "large" in diameter to make good torque. Most aren't aware that the tubing used in the headers' construction is 14 ga. rather than the thinner 16 ga. used by most other manufacturers. The increased tubing wall thickness causes the external size to be larger than what the eye is used to seeing. Don't be confused...the engine only "sees" the inside diameter.' -TOO
Ceramic Coated full 2.5", for pricing email staff@theoldone.com.
Nuf Said.
Re: what exhaust to run with jrsc,header? (snapcase318)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snapcase318 »</TD></TR><TR><TD CLASS="quote"> thermal research turbo cat-back? </TD></TR></TABLE>
I would second that remark.
