what do you guys think? Yay or nay?
I stumbled across these mounts but i wanted to put them on my d16z6. Will they fit? Need some help ASAP my mounts are gone ...
http://cgi.ebay.com/ebaymotors...ZWDVW
Re: what do you guys think? Yay or nay? (Ej Girl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej Girl »</TD></TR><TR><TD CLASS="quote">Those are b series mounts, you need d series mounts for a d16</TD></TR></TABLE>
B series and d series are the same it just depends if you have 2 bolt or 3 bolt mounts
Re: what do you guys think? Yay or nay? (egsleepercivic)
If you go to the link provided it clearly states
" Fitment: 92-95 Honda Civic (with B-series swap)
94-01 Acura Integra with B-series engines only
93-97 Honda Del Sol SI (with B16A engine) "
So it wont fit on his car.
so what should be good. i need something that wont hurt my pockets lol. For the right side transmission mount is the only thing different between a B and D series is the bracket?
Re: what do you guys think? Yay or nay? (twentytwocpb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentytwocpb »</TD></TR><TR><TD CLASS="quote">so what should be good. i need something that wont hurt my pockets lol. For the right side transmission mount is the only thing different between a B and D series is the bracket? </TD></TR></TABLE>
That and acouple different mounts. Try looking for D series mounts so you wont get the wrong thing.
true but alot of mounts like innovative mounts say that they are for B AND D series engines. So i just thought all others would be the same ......which if theyre not.....than thats GAY! lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej Girl »</TD></TR><TR><TD CLASS="quote">If you go to the link provided it clearly states
So it wont fit on his car.</TD></TR></TABLE>
the 94-95 d16z6 mounts are the same as 94-01 teg mounts, only diiference is rear bracket which is usually referred to as mount but it is not even included in that kit
OP what year is your civic, does it have 3 post mount on the drivers side or 2 post, then we will be able to answer your question
its a 95 EJ1 Coupe and it has a two bolt post on the drivers side and a 3 bolt on the passenger side
Actually thats not true. If you get the mounts for a JDM B series engine, the rear and the drivers side mounts will work. This is because on the JDM spec engines, a 2 pronged drivers side post is used, just like on D series engines and the rear mount will also line up. The only mount that won't line up correctly is the transmission mount. You could buy some baller status Hasports and just not use the transmission mount, if you absolutely need mounts that is...
Re: what do you guys think? Yay or nay? (JDM EJ2)
finally! someone knows something. thats what i was thinking too. for the right side transmission mount.....i heard the only thing different was the bracket for the mount
jaminonyourface
10-01-2003 10:55 PM
