What do i need to install the Skunk Camber kit??
Hey guys next weekend ill be doing a skunk camber kit install what tools will be needed?
Also anything i should know before i start any tricks?
Re: What do i need to install the Skunk Camber kit?? (Spence)
Camber kit? Front Or back? Upper control arms? Need a little more info than that. But Just make sure you have the balljoints pressed into the control arms before your go taking everything apart. I do not suggest hammering them out of the old ones and into the new ones. Just basic hand tools for that one. 17mm, 14mm, and assorted others. I would also have a jack to put under the lower fork to jack the whole spindle up. This allows you to attach the castle nut to the balljoint easier. Otherwise the damn balljoint will just keep spinning, getting you nowhere in trying to get the castle nut on the threading. AND if this isn't a UCA kit, that's your fault for not specifying that earlier. LOL Good luck and it really isn't bad at all.
88crx-si
05-09-2006 07:22 PM
