what do COMPRESSION RATIO mean?
what do these ratios mean? its on c-speed, the COMPRESSION RATIO. can someone verify what compression ratios are.
Re: what do COMPRESSION RATIO mean? (Emerika)
take 10, 1 litre bottles. fill them with water. and then try to jam all of that water into 1 container.
10 into 1. or 10:1
thats a lot of pressure for that area. because its "compressed" and the more compressed the a/f mixture is. the more BOOm you get.
10 into 1. or 10:1
Solbros Owns Me
Re: what do COMPRESSION RATIO mean? (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">take 10, 1 litre bottles. fill them with water. and then try to jam all of that water into 1 container.
10 into 1. or 10:1
thats a lot of pressure for that area. because its "compressed" and the more compressed the a/f mixture is. the more BOOm you get.</TD></TR></TABLE>
was my explaination not good enough???
why do umpeenth people need to say the same thing over....give a little thumbs up if you wanna bump it
10 into 1. or 10:1
Re: (Emerika)
Compression ratio is the ratio of the volume inside the cylinder with the piston at bottom dead center over the volume at top dead center . CR=volume BDC/volume TDC. You then get a ratio of how much stuff is compressed inside the cylinder.
Re: (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">Compression ratio is the ratio of the volume inside the cylinder with the piston at bottom dead center over the volume at top dead center . CR=volume BDC/volume TDC. You then get a ratio of how much stuff is compressed inside the cylinder. </TD></TR></TABLE>
a technical answer..
Re: (AlphaQup)
Thinking about this more, it's not shoving 10 units of anything into 1. It's taking 1 unit and compressing it 10.1x if the compression ratio is 10.1:1. Compression ratio is actualy a ratio that relates to the pressure.
