Whar raidiators will fit my civic?
OK guys... The raidiator blew monday on the way to school. Im trying to find one, but no luck. It's a 92 Civic LX. Are there any other models that have the same raidiator? Because Autozone wants like 230 bucks for a new one.. waaay too much.
*ALSO* If there is anyone from the memphis area with the raidiator that I need, or has a hookup where I can get one, hit me up! Thanks!
*grins*While checking one junkyard I found a set on NGK spark plugs for my car just sitting in one of the cars... they just gave em to me :D
[Modified by TheFLY, 9:30 PM 11/14/2001]
Re: Whar raidiators will fit my civic? (TheFLY)
any radiator from a 92-95 will fit.....probably 92-00!!!!
you can get just about any radiator and make it fit as long as the ends are the same size.
Re: Whar raidiators will fit my civic? (Spade)
ok... I also just noticed something.. .while changing wires today, I noticed quite a bit of oil in the #4? (closes to the distributer) Spark plug hole... and the others didnt really have oil like that. Is there something wrong?
you have a bad spark plug gasket. easy to replace. go get 4 new ones at the dealer and take your valve cover off and RnR.
Re: Whar raidiators will fit my civic? (eg6_LHD)
QUOTE: you have a bad spark plug gasket. easy to replace. go get 4 new ones at the dealer and take your valve cover off and RnR.
Does this hurt anything? How much of a priority should it be to fix this?
vectorsolid
10-08-2007 02:46 PM
screename
09-24-2006 05:57 PM
SHystrdyGSRtdy
08-09-2005 11:47 AM
