Wet or Dry in my 93 del sol?
hey i have turbo del sol with lots and lots (too many) modifications under the hood and i had a 75 wet shot straight from ZEX but i want to buy the new Venom kits because my sponser said that they came out with this bad *** new kit this year. But i dont know much about Venom so please inform me whether i should use WET or DRY shot nitrous for my del sol and how much(50,75,100)?
eric
eric
Re: Wet or Dry in my 93 del sol? (thedelsol)
IMO-depends on what kind of fuel pump, injectors, and other fuel management things you have. if they will be able to supply the extra gas needed by itself ....then you can do dry, but if you want to be safe, forsure, I'd do wet. Zex is a good setup. I never touched venom before. anyone else?
EDIT: Oh yea, I wouldn't throw more than 75 shots on your setup. I, with a HUGE I, would only use 50 shots. Being safe...i dont have money for another motor. Already done my swap for the year
Are you runing on stock internals or no? I wouldn't try to push more than 200-220hp out of your D block on internals. It will ****.
Re: Wet or Dry in my 93 del sol? (jar)
WET 55 if you would like to keep your motor for a long period of time, 75 is ok but the end result almost all the time is boom. Also I guess it depends on what motor your running as well D-series are weaker then a B-series so the B would handle a bigger shot longer.
fatalman
11-29-2005 07:40 PM
