Water pump problem
Water pump problem
I have a water pump leak. Idk if its the water pump its self or the head gasket. Both look fine. It wont hold coolant in the water pump at all... it leaks right out of the bottom. If your facing the water pump, its the bottom right screw its leaking from
Re: Water pump problem
If the pump is flowing fine then it's the gasket. Or it could be the pipe the feeds the pump, if that leaks hen **** runs down the back side of the pump and comes out the bottom. So it could be that o-ring or the wp gasket itself.
i would not use any, the orings they supply are really nice (i take it you are using oem honda parts). i would recommend you building you a crank pulley bar. it's a must to get that off (or was in my case). I tried everything (including a 1" impact gun on 200psi), and a 7' piece of pipe on a breaker bar with the pulley brace was how i finally got it off. and it sounds like the seal itself on your water pump is leaking (it leaks toward the firewall right at the pump). oh yeah, we used a inch and a half piece of angle iron about 4' long and marked the holes in the crank pulley, it was simple to make.
of course it would be a good time to replace the timing belt and the idler pulley while you are in there good luck!
the water pump has a "weep" hole out the bottom to keep the seal leaking toward the ground and not all into the timing belt cover. look for that weep hole and you will be able to tell if it's the gasket or the pump shaft seal itself. either way i would change both while i was in there.
Do not use any honda bond or any silicone. What is the point when there is a gasket on it that works just fine.
I work in a honda dealer and do pump often enough-never use any silicone and never have an issue.
RenoRacing
10-28-2002 04:52 AM
