water pump line goin to thermo is leaking
I have replaced the o ring 4 times. the first 3 got cut in half and then i went to the auto parts shop and got a oring that fit tighter, but it s still leaking. any advice?
Re: water pump line goin to thermo is leaking
did you clean it out before you put the o-rings back on, try making it smooth with some sand paper or steel wool, and make sure the o-rings are the right size becuase they are kinda thick
Yep the motor is brand new, i used steel wool on it every time i replace it. I think im gonna try a new water line.
use a dab of sealant to hold the o-ring in place.
Sounds like its slipping off when you assemble it and then gets crushed and leaks.
nonvtec92
05-10-2008 09:36 PM
