VX/SI gauge cluster swap?
The cluster from my 95 VX 3 door was stolen. I've found several used
clusters from SI models (which also have the tach). Would this be a
simple plug/play swap or are there issues or incompatibilities between
the two?
thx for any help you can offer
Duncan
the two?
Duncan
Location: Why so you can pretend like youre interested, FL/OK
Re: VX/SI gauge cluster swap? (dwnthehatch)
I believe mine is near 7200 rpm, but I am at work currently and could be mistaken.
Will an SI/EX cluster plug right into a 95 CX hatch? A friend of mine asked me if it would and I wasnt sure..so here I am lol...
thanks
thanks
Re: VX/SI gauge cluster swap? (Si.Hatch.92)
if your talking about 92-95 yia it will. i swaped my dx for a vx cluster. i didnt know it was a vx till a member on ht helped me out. where would my car be without the info from ht
Did you read the posts above yours?
Any 1992-1995 civic guage clusters are "plug
and paly" If your stock cluster has a shift light,
and if you replace it with a higher model cluster
that was equiped with cruse controll, then the
cruise controll light will light up like your shift light
did.
did.
Re: VX/SI gauge cluster swap? (d15dude)
did.
did.
thanks for the replies. one clarification: would clusters from the 2/4 door
civics be swappable into the hatchbacks?
Also is there a standard name for the "trim" that goes around the cluster?
My car was vandalized and I have to replace all of it, the air vent mouldings,
the part with the pushbutton 4-way flasher, etc.
"Did you read the posts above yours?
and paly"
Yeah but I'm not an expert, I didn't know if the poster was only
referring to hatchbacks or if this included sedans. So now I
assume it does, based on your reply.
Also one guy at a junkyard told me the cluster from an automatic
wouldn't work in a manual. Is this true? I don't know what would
be different.
That's why I'm here, because I need answers, and I appreciate the help.
[Modified by duncan, 5:49 PM 3/12/2003]
and paly"
be different.
civiccpedx
09-29-2004 04:49 PM
ImolaS54
10
11-23-2003 08:27 AM
duncan
03-10-2003 08:57 AM
