VX Block off Plate on CX Hatch
Alright, well i just purchased the block off plate for my Hatch. My question... Do you pull the entire Antenna wire out? I just cut it off and used electrical tape to tape it in the A-pillar so it wouldn't rattle around. (not like I don't have enough) Obviously this isn't the "correct" install but it will work until it gets warmer. Thanks for your advice.
Scott
Scott
Re: VX Block off Plate on CX Hatch (bryan305)
Yes, the part number is 39152-SR3-A00 Pricse is $3.68. Don't make them talk you into getting the gasket, because you already have one. I'm stupid and got one too . If you want the gasket though that part number is 39154-SR3-G01 and the price for that is $4.02 Here's a pic.
Re: VX Block off Plate on CX Hatch (SlippylesKB)
is that the same for ek? i've been looking for one. the honda parts by me said it was for canada only? is that true?
Re: VX Block off Plate on CX Hatch (enrique)
When I did it I pulled the enitre antenna, and antenna wire and got one of those "Metra" antennas that mount on the windsheild. Most people go that way, the metra just plugs into the antenna outlet so you do want to pull the OEM antenna cable out.
Re: VX Block off Plate on CX Hatch (KOALA YUMMIES)
Do I just yank as hard as I can? I think I'm just going to stay radioless... I like my CD's
Scott
Scott
And to help the EK owners, I found the plate in the Speaker Mounts/ Brackets section for the car. Search there.
Scott
Scott
I unpluged it from the radio, and cut it right near the hood release, then just yank the crap out of the antenna and pull the rest of it from behind the radio. Putting the metra or another antenna in is really easy, just plug in, splice to a positive key-activated acessory (like the cig lighter) and then route the wire to the antenna through the A pillar. Plus the metra antenna is a lot better than stock crap.
Just installed mines last night. All I did was rip out the antenna and tapped it up.
here you go:
BEFORE
AFTER
Cost me about $7 bus to replace eveything. Block off plate/ New screws/ New washers/ New gasket.
here you go:
BEFORE
AFTER
Banned
Re: VX Block off Plate on CX Hatch (Spooner)
i have one of those i was GOING to put on my car but didn't (since it was stolen). if someone wants it, PM me and let me know.
Banned
Re: VX Block off Plate on CX Hatch (MaSpec-SiR)
I work at Honda and a 92 CX w/ 76,000 miles on it came in yesterday. It had the Radio block off plate and the antenna block off plate. A 70yr. old lady was driving it. It was in perfect shape. I had a boner.
Re: VX Block off Plate on CX Hatch (BERT-O)
got mine straight from the dealer, $7 i think it was. i just cut the ant. rod, and pushed it up on the body, under the cap. i radio still works fine. only onee station i don't get so good, but i don't care about that one staion.
Re: VX Block off Plate on CX Hatch (SpooN Man)
get an mp3 deck you never want to listen to the radio again
Scott
Re: VX Block off Plate on CX Hatch (buddha429)
So my question is, which Metra antenna are you guys replacing the stock one with? I want to get rid of my "whip" Honda antenna and go low key but still want to listen to the radio.
Jon Black
Jon Black
Re: VX Block off Plate on CX Hatch (Jon Black)
I dunno but I just got an idea. What if you taped the wire to the body, wouldn't your whole car act like an antenna (this may be a dumb idea that obviously doesn't work, but I just woke up)
Scott
Scott
I bought a powered one that goes on your window. works fine so far but for some reason one station doesn't come in too good but then again it is barley picking up La radio stations it never did before
