vtec head on 93 CX block what ECU will plug in and work?
if i use my stock harness and i run the wire for Vtec what ECU will plug in and work with a 95 SI head? an SI ECU or EX or what? what happens if i use my ECU ? also where does the Vtec hook up wires go ?
Re: vtec head on 93 CX block what ECU will plug in and work? (derrickcxhatch)
and you need too wire a 4 wire o2 sinser(sp)
you would be better off looking for a d16z6 if you ask import shops thay sell for really cheap $300-$700 is the going price
Or if you don't wanna go through with all that get u a MSD RPM Activator Switch. Thats what i did and works fine my VTEC kicks in a 4800RPMs CRX-T did the wiring for me.
So you might wanna Im him
And you need a VTEC-E (1.5 VX) Timing Belt since the d15s are shorter then the D16
[Modified by ace1875, 5:41 AM 1/9/2003]
ilovemyb16a
05-18-2006 12:58 PM
shbrown
08-11-2005 04:51 PM
