vss wiring
vss wiring
I have a 95 civic with b18a and i used the stock dx harness i had but the vss plug is cut somewhere inside the harness. Does anyone know how to wire this to the ecu or back in the harness. i looked all over the harness and cant find where it was cut off at.
I searched but know luck
Re: vss wiring (HybridRacer69)
http://www.ff-squad.com/tech/w...t.zip
That Should help you I PMED you but you did not answer. I would start at the ECU and find B10 it is a yellow/blue wire. cut it splice a new wire and run it to your VSS. Hope that helps
Al_9000
19
06-01-2005 08:49 AM
1 Cam Wonder
19
10-10-2004 08:49 AM
cr00klyn718
07-13-2003 10:59 AM
