Vision suspension
Vision suspension
Hey there, I recently picked up some used Vision/Showa coilovers for a EG6 but the problem is that the rear is set up like the ITR and (similiar to the 88 civic/crx. Meaning the bottom of the strut is different in the way it fits into rear LC'As) The question is this, are there any compatible lca's that i can swapto make fit? And if so can it be just be the lca's not the whole rear setup?
Any information would help on this stituation --thanx
Or should i just say F it and sell them?
pics later (They should help explain)
Re: Vision suspension (b16a1sirhb)
You just need the appropriate rear LCA's that you mentioned above, and just bolt everything up to your car. You should be good to go.
atc5
21
11-29-2005 10:16 PM
