Viper alarm HELP please....
I have a 4 button Viper Alarm system The case is shaped like an egg and is dark blue. it has lock(upper left), unlock(upper right), AUX(lower left), and Panic(lower right in orange).
I was messing with my doors with actuaters and kept pushing the lock-unlock buttons and it went into valet mode(red led stays on).
HOW DO I GET IT OUT OF VALET MODE? I have a pushbutton valet switch under dash(1 button only).
I've tried: putting door open and pushing 1-2-1. I tried holding down the valet button while i turn the key to the ON position.
I don't know what else to try. Any help would be much appreciated.
Re: Viper alarm HELP please.... (sokdo321)
open your door...make sure the dome light is set to door.....on the key pad...hit unlock lock unlock....
if that doesn't work........open the door....put the key in the ignition......turn it to the on position.....then turn it off........take the key out....and hit the valet button.....
it'll work...i'm a installer.......if not ur door trigger is probably messed up
