Valve ajustment? or?
Re: Valve ajustment? or? (wspcivic)
Mine does that too. My mechanic said to do a valve lash and that should fix it. I'm getting it done monday so if it works I will let you know.
The noise going up hills is detonation from using cheap gas and/or from worn ignition componets like plugs, cap, wires, rotor or a timing issue.
Re: Valve ajustment? or? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Ok, what gas do you use? And what was your timing set at?</TD></TR></TABLE>
cam and ignition
cam and ignition
Then your running a lower octane gas with advanced timing and pulling a load, hearing a slight detonation is to be expected.
Tr0LL
06-11-2003 01:17 PM
