Vafc Killed My Car!!
I recently installed a vafc in my car. Now it is running EXTREMLY ritch! It wants to stall out under 3,000 rpms. If you give it some gas it will power through it. It only does it under 3k. Im also throwing a code 3 (MAP sensor) My car is a 97 civic dx (obd2a w/ d16y7)
Please help!
Please help!
Re: Vafc Killed My Car!! (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">I recently installed a vafc in my car. Now it is running EXTREMLY ritch! It wants to stall out under 3,000 rpms. If you give it some gas it will power through it. It only does it under 3k. Im also throwing a code 3 (MAP sensor) My car is a 97 civic dx (obd2a w/ d16y7)
Please help!</TD></TR></TABLE>
Are you sure you did the initial set up correctly, according to the Apexi manual? Are the sensors set correctly on the VAFC?
Because you haven't hit the dyno, you should have all of the fuel settings at 0 for the time being.
I thought V-AFC's came with no adjustements stock. If you set it up and installed it correctly it should be just like it was, correct?
Re: Vafc Killed My Car!! (red91sit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91sit »</TD></TR><TR><TD CLASS="quote">V-AFC's come with no adjustements stock i though, so if you set it up and installed it correctly it should be just like it was correct?</TD></TR></TABLE>
Unless he bought it used, or didn't do the initial set up correctly.
Re: Vafc Killed My Car!! (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">no need for a VAFC with a stock Y7, should've done youre research first</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Why did you put a VAFC on a Y7?</TD></TR></TABLE>
I did my research.
I was planning on putting in my rc 410's. Which are for the t3/t4 that is siting in my garage. But now this has put a little dent in my plans. I used the pin out for a y8 to hook it up. All the wires are the same except the vtec wires. i dont know what could be causing this. I even disconnected the unit and the car still behaves the same way. I tried setting everything at 0 and it did nothing
I did my research.
Re: Vafc Killed My Car!! (Padawan)
maybe it was the person you bought it off of fagen, j/k. bump b/c i watched this go in the car on saturday...shouldve gotten the wheels....
Re: Vafc Killed My Car!! (BrokeAssPinoy)
thats a little rough there jim... seriously tho how many times can we say it uve gotta get that thing tuned. ur pretty set on ur stock settings but it needs to be tuned. i must stress that it needs to be tuned!
any news on ur map sensor?
Re: Vafc Killed My Car!! (beav)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beav »</TD></TR><TR><TD CLASS="quote">i dont get why you would put a vtec controller on a dx.</TD></TR></TABLE>
I was planning on putting in my rc 410's. Which are for the t3/t4 that is siting in my garage.</TD></TR></TABLE>
read thread prior to posting..............
Re: Vafc Killed My Car!! (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">read thread prior to posting..............</TD></TR></TABLE>
He still didn't need the vtec controller. He could've just bought the air fuel controller.
sorry bud but my 96 Dx doesnt have v-tec!! you must have one of those special Y7s that do!! ohh nevermind they dont make one!!!!!
Re: Vafc Killed My Car!! (97mini-me)
I picked it up for 150$ and it does everything the air fuel controller does and more. Why not put it on? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio »</TD></TR><TR><TD CLASS="quote">hahaha.. v-afc on a stock y7.. rice at it's best......</TD></TR></TABLE>
As I stated before i am going to be running the hack with rc410's so my **** is NOT
STOCK!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS8HFL21 »</TD></TR><TR><TD CLASS="quote">maybe it was the person you bought it off of fagen, j/k. bump b/c i watched this go in the car on saturday...shouldve gotten the wheels.... </TD></TR></TABLE>
Yeah i think so to. I allready found out that he had the vtm splice on the wrong wire
Didn't fix the fuel problem though
it doesnt matter if he gets a SAFC or VAFC they both do the same **** just the vafc has vtec option, they go for the same price, that ive seen, what if he later gets a vtec head/swap, i just see arguing, ******* noobs
