Urgent: D16y8 how to do a valve job with the cylinder head off!! HELP
Ok just removed head from block I would like to know is there anyway i can remove the whole camshaft assembly and rocker arms in 1the shot? Also i notice looking at the lower plain of the block it appears my 2nd cylinder exhaust valves are sticking out a tiny bit..
PLZ HELP I have the manual but am at a stand still. I don't want to remove each thing piece by piece
Thank you
Thank you
Re: Urgent: D16y8 how to do a valve job with the cylinder head off!! HELP
lol undo the cam girdle on top it's the only bolt's you'll be looking at. on a side note hold it when you remove it's a pita if you mix up the rocker arms. Ya of course a few of the valves will be open every cylinder can't be on the compression stroke.
I circled the bolts in red, just undo them and the whole assembly lifts out
thebleek
10-01-2008 08:03 AM
sony224422
01-04-2008 12:20 PM
