Uhm im kinda dumb. weid noise
So i am not good at diagnosing problems but when I am in high third gear my back wheels or axle or something starts clicking. And its only a short time then stops. Help?
Electrician
Re: Uhm im kinda dumb. weid noise (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 »</TD></TR><TR><TD CLASS="quote">you sure its not upfront cause it sound like cb joint to me</TD></TR></TABLE>
You mean CV Joint.
If it was the CV Joint, it will be clicking pretty much all the time.
Maybe something is loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplypinoyy »</TD></TR><TR><TD CLASS="quote">not only are you kinda dumb... but cant spell either...</TD></TR></TABLE>
I didn't find a word that was misspelled. You mean his grammar isn't up to par. If you are going to correct someone, at least know what the **** you are talking about.
You mean CV Joint.
Re: Uhm im kinda dumb. weid noise (simplypinoyy)
Yeah....to the original poster: You do not have a back axle, period. Go to your rear tires and push and pull on the top of them to see if they have play (movement) in either direction. If you don't notice anything there take off the rear tires and grab the whole drum brake (or disk brake) assembly and rock it back and forth (it shouldn't...if it does replace the hub bearing). For the front if its clicking it could be a cv joint, or a hub bearing up front. My friend's tire almost fell off (geo storm gsi) because of his rear bearing....it looked like he had some serious camber...in a stock ride hight and it would wobble while at speed.
Re: Uhm im kinda dumb. weid noise (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">You mean CV Joint.
yeah sorry
yeah sorry
Re: Uhm im kinda dumb. weid noise (GTlvr82)
I'm thinking that your wheel bearing might be going out? Or if you think the noise is coming from your axles, then it might be that your tranny is grinding? Correct me if I'm wrong but you got me confused, You say that you hear noises from you back wheel but you also state something about your axles?
Re: Uhm im kinda dumb. weid noise (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso »</TD></TR><TR><TD CLASS="quote">I'm thinking that your wheel bearing might be going out? Or if you think the noise is coming from your axles, then it might be that your tranny is grinding? Correct me if I'm wrong but you got me confused, You say that you hear noises from you back wheel but you also state something about your axles? </TD></TR></TABLE>
I explained the axle thing already...
Original Poster you need to have a friend listen while you drive to see where the sound is coming from....
Ideal
04-05-2005 11:40 PM
D for D series
01-29-2005 09:08 PM
