Turn signal issues....
Old 02-12-2010, 03:26 PM
thelate1's Avatar
Default Turn signal issues....
I recently swapped my 94 Hatch. Before installing the motor I cleaned up the harness in the bay by deleting the plugs I didn't need. I got rid of the A/C, so I removed the separate harness that had the A/C stuff plugged into it. Well, I finally started the car and the headlights work, but none of the turn signals do. Everything worked fine before the swap. I checked the fuses, and the hazard switch. When pressing the hazard switch, all four corners blink fine. I searched around and the only thing I can think of is I deleted something I shouldn't have, or the relay randomly burned out, or it's a bad ground. Now, I thought the only turn signal relay is under the steering column not out in the bay?
Old 02-12-2010, 04:14 PM
Relic1's Avatar
Default Re: Turn signal issues....
if all four turn signals blink with the hazards on, the relay and wiring to the lights is fine.
you disconnected something under the dash near the steering column.
Old 02-12-2010, 04:30 PM
thelate1's Avatar
Yeah, that's what I thought. Now here is something I forgot to mention. The previous owner had some hacked job alarm installed. I took it all out wire by wire and soldered the wires back together and shrink wrapped them. I will have to make sure nothing was done to the relay.
Thanks for the help!
hybridnorth
37
02-16-2019 06:13 AM
mike541
01-07-2012 03:09 PM
obd1_crx
09-19-2008 11:32 AM
biggentplayer
12-19-2006 10:28 AM
johnnyb1231
01-25-2006 11:57 AM
Quick Reply: Turn signal issues....
