Trunk bar for an Ek
Trunk bar for an Ek
Just incase anyone ever wanted a trunk bar, or wants to reconnect the sub frame after removing the rear bumper support for the reason of weight or because of a body kit, the 95 del sol front upper strut bar will bolt right into the trunk at the stock 4 bolt locations with no mods.
Just wanted to share this cool little hybrid thing I figured out a few weeks ago. I had one lying around, so it wasn't a bad free upgrade. My handling actually improved a bit. It def tightened it up a bit!
* B A N N E D *
1 Post
Re: Trunk bar for an Ek (www.megameet.org)
whats a trunk bar? do you mean the front del sol bar bolts onto the back STRUTS of the EK chassis? or does it bolt to where the metal rear bumper goes IN PLACE of the rear metal bumper, which is under the plastic bumper cover?
Re: Trunk bar for an Ek (Redline96LX)
mine doesnt have those factory, at least ive never seen them what are those bars? didnt get what he was saying
can you actually take a pic of yours, those bars dont look like strut bars
i know the EG has big bolts in the trunt at those locations, you can remove them and re-insert them through whatever bar he's talking about
Ek's have the holes, there are 4 19mm bolts threaded through them. That is what holds your bumper on. Not the fascia but the actual metal bumper.
* B A N N E D *
1 Post
Re: Trunk bar for an Ek (Jeremy D. Swain)
So for an EK, this isnt IN the trunk, its like...behind the metal bumper? Behind the plastic painted bumper cover, this is behind the metal-designed-to-crumple-bumper?
if you open your trunk/hatch...there are four bolts..underneath your carpet and cardboard thing that covers your spare, the bolts hold the rear metal bumper where it inserts underneath the car (what a guy above said) I always thought they held your gas tank up.
Re: (ek_99_SiR)
all the explanations have been right. Since I no longer have my "bumper support" behind the factory plastic bumper, I used this bar to re-connect my FRAME and thus improved my handleing by helping to stop chassis flex.
It was a free mod, and now you all know that for the EK that the del-sol front upper strut bar is a hybrid convertion that works for this so you can save some CASH! I used the D.C. sport one for this.
Because I dont have the bumper support in there was no "nuts" to thread the bots to. I had no bolts, So I had to add in nuts and washers by hand through the frame to put this in. I did it with the bumper on. (no metal support though) and it wasn't to bad at all.
Re: (www.megameet.org)
Here is the http://www.emracing.com one......
This is connected to the strut bar for the strongest possible regidity.
WOWOWOW THAT Z IS ORGASMIC hahaha that looks really good but does that ONE bar do that much? idk maybe i just dont know where the chassis flexes...fill me in? where are the points u can put bars and which are most effective?
Re: (markysparky)
go to the site I just posted to see the rear ones. The front is different. I want a traction bar and the frame support for the front next.
I just put on front and rear lower sway bars as well.
