transmission woes?
transmission woes?
sometimes i cant get into reverse, like theres a wall or something
i have to keep trying, or let the car roll a few inches and then i can go into reverse...anyone know whats going on?
and at around 3000pm in certain gears i hear like a whirring noise...?
any input would be awesome
thanks in advance
thanks in advance
Re: (Dimi)
ok...this is going to sound stupid
do i add the tranny fluid? if i were to change it, where do i bleed it, or flush out the old transmission fluid.
Re: (otakueric)
Go to the local auto parts store and buy a service manual for your car. There you will find instructions on how to change your tranny fluid. A service manual is good to have around anyway if you plan on doing a lot of wrenchin on your car.
Re: (otakueric)
look it's easy as hell, might wanna jack up car first it'll make it easier. First there are 2 plugs on the side of the tranny, the upper one you remove it to let air in so the fluid will drain faster out of the bottom plug, (just like you do when you change your oil) remove that plug first then do the bottom one to drain it out. Install a new washer on drain plug, tighten plug, put about 2 quarts honda mtf or gm/pennzoil synchromesh in through the top hole and tighten plug, lower car, drive away and be happy.
Re: transmission woes? (otakueric)
check this out dude. it'll help you tons of much. https://honda-tech.com/zerothread?id=382416
Re: (Dimi)
I put syncromesh in mine and 3rd gear started to grind right after the change. I know it was full, this wasn't my first time changing it. I put the honda in it, and now it shifts like new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otakueric »</TD></TR><TR><TD CLASS="quote">sometimes i cant get into reverse, like theres a wall or something
thanks in advance</TD></TR></TABLE>
signs of a worn out tranny ..as for the reverse problem. go into 2nd, then quickly take it out and jam it in reverse. works for me everytime.
