TPS keeps breaking because my motor shakes like crazy
Old 06-01-2012, 09:21 PM
aflyingpanda's Avatar
Icon3 TPS keeps breaking because my motor shakes like crazy
I just recently did a b16a swap in my 96 ek sedan. I haven't replace any mounts but the driver side and need to asap!
so my motor shakes like crazy and the plastic that goes to the plug to my tps sensor broke and then the tps gets disconnected and causes my car to bog and spazzes out like crazy and won't let me go past 2100 rpm.
I am not able to purchase mounts atm since i am low on cash and gotta wait til my next pay check to get them which is not for another two weeks.
What can i do to keep my tps from at least disconnecting and breaking. I was thinking of using gorilla super glue to glue the lil plastic piece back on but idk if that would hold up good enough. This is my daily so I need this car to get to and from work.
HELP PLEASE!!!!
Old 06-02-2012, 01:52 PM
Default Re: TPS keeps breaking. HELP
so no one can help mee?
Old 06-02-2012, 01:56 PM
The Grumpiest
grumblemarc's Avatar
The fix is to get new mounts if your engine is shaking that violently. Anything else you do will be a hack job. You could probably use the universal fixit solution; duct tape.
Old 06-02-2012, 03:37 PM
itsnotfast's Avatar
As grumblemarc said it would be a hack job but you could extend the wires. This would be a working fix but you really should just get the mounts. You'd be chopping a prefectly good harness and that never looks good.
Old 06-02-2012, 04:26 PM
EL MIGGZ's Avatar
Look at the plug, take note on the order the 3 wires go, unpin and connect straight into the tps. Should work if not go to the junkyard cut the plug off un pin and just swap the plugs.
Old 06-02-2012, 04:39 PM
Retired Moderator
EsotericImage's Avatar
1. Dont drive all crazy till you get mounts
2. buy mounts
3. replace mounts
4. fix/replace your TPS for the last time
you can get hardrace mounts for cheap
http://www.velocityshop.com/product/...civic_326.html
Old 06-02-2012, 07:37 PM
hmm extending wires would actually might be a good idea for now.
2. buy mounts
3. replace mounts
full race mounts are more expensive then innovative :\
Old 06-02-2012, 07:47 PM
Retired Moderator
Hard Race Mounts
click the link
Old 06-02-2012, 11:35 PM
Hard Race Mounts
click the link
I did my bad lol i didn't notice what I was typing. But yeah Hard Race.
They're like 280 and innovative from swap shop is only 250. And I heard lots of good from innovative
Old 06-03-2012, 02:39 AM
The Grumpiest
Whatever. What's wrong with OEM? Cheaper than both.
Old 06-03-2012, 08:22 PM
my motor is built. so when i take off my motor hops nasty
Old 06-05-2012, 08:52 PM
itsnotfast's Avatar
Aside from suspension and wheels, mounts are the first thing I do to any of my cars.
Old 06-05-2012, 09:15 PM
beecee18's Avatar
enery suspension, and/or prothane MM inserts for the stockers @ 30$ total
you will burn that much gas showing off your new swap
add to cart!
Ohh yeah,
thanks for the killer siggy!
Old 06-05-2012, 10:45 PM
jbpnoman's Avatar
The motor hopping is not caused by a "built" motor, it's caused by blown mounts, and a driver who doesn't know what he's doing.
Old 06-18-2012, 07:47 PM
EL MIGGZ's Avatar
Originally Posted by beecee18
Ohh yeah,
Roflmao!! Stock mounts + energy inserts FTW!
X2!
rexfan
05-31-2008 07:25 AM
EK SQUAD 425
03-25-2006 05:56 AM
00WhiteEKy
05-30-2003 09:57 AM
patastinky
03-31-2003 02:16 AM
Quick Reply: TPS keeps breaking because my motor shakes like crazy
