Torque on wheel bolts
How much torque should I apply when remounting my wheels? After changing a flat I dont know if it is tight enough.....I dont want it to fall out when driving
Thanks
Thanks
Re: Torque on wheel bolts (Kikomon)
umm... no. the stock honda wrench is nearly a foot long, so you are putting 145ft-lbs on it.
In order for you to actually get 80ft lbs by standing on it, the wrench would have to be about 6.5" long...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">
well I had them torqued prviously and It took me steeping on the edge for it to drop...</TD></TR></TABLE>
I don't get it... you torqued them properly and then stepped on the wrench to overtorque them...
were you leaning on the side of the car or something? Torque wrenches are very good investments
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I just use the wrench that came with the stock honda jack...and i stand on it until it doesnt move anymore (I'm under 170 lbs so its okay)
</TD></TR></TABLE> thats way to much. if u get a torque wrench, it would be torque over 120 lbs
New User
Re: (BauleyCivic)
if you do that, you're putting 160-180 FT.lb. on your lugts. i jus lean on the bar with my arm and half my body weight. it usually torques its to about 100ftlb.
Re: (Mr. Choi)
80lbs...and thats that....
never really realize how important this is til...something bad happens
was anyone else at button willow when the team orange EK's wheel popped off on the skid pad turn??? dude!!!! that'll scare the **** out of you and make sure to double check your wheel lugs
Re: (BauleyCivic)
thats what I do, im 135lbs. of course im a weakling so I gotta stand on everything, especially when Im loosening.
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">i just take the stock tire iron and tighten it up by hand. how much torque do you think that is?</TD></TR></TABLE>
140.
140.
Re: (D16 madwoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16 madwoman »</TD></TR><TR><TD CLASS="quote">
thats what I do, im 135lbs. of course im a weakling so I gotta stand on everything, especially when Im loosening.</TD></TR></TABLE>
i'd be afraid of snapping the wheel stud, applying extra force in teh wrong direction. especially if you are bobbing up and down on teh bar
Re: (phantom_sol)
Sometimes that what it takes if they weren't torqued properly to begin with. I'm just over 180lbs and I was rotating the tires on my woman's civ. I had to pull so hard that the car was rocking. The last idiot that put them on must have been using an airgun...
Re: (ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ng »</TD></TR><TR><TD CLASS="quote">It's just as easy to stand on it. Works for me, haven't lost a steelie yet =D.</TD></TR></TABLE>
again... you are overtorquing your wheels... You aren't going to lose one if you put 150ft/lbs of torque on it and it only requires 80...
