Torque specs for D16Y7 valve lash?
Old 06-05-2004, 03:21 PM
Aquafina's Avatar
Default Torque specs for D16Y7 valve lash?
EDIT:
Got the torque specs.
Last night I started with cyl 1 at (UP at the little arrow on the timing belt cover).
I then moved it to 12 o'clock after reading to do so in another thread.
Do I do cyl 1 at the arrow or 12 o'clock?
I know to rotate by "3 hours" for every cylinder already.
Modified by Aquafina at 3:40 PM 6/6/2004
Old 06-05-2004, 03:59 PM
Aquafina's Avatar
Default Re: Torque specs for D16Y7 valve lash? (Aquafina)
Anyone?
Old 06-05-2004, 04:06 PM
Jim Truett's Avatar
If I remember correctly the spec is 120 in/lbs.
Old 06-05-2004, 09:05 PM
Aquafina's Avatar
Thats 9.x ft-lbs. Lowest my wrench goes is 10 so thats what I did.
I set all valves to I .8 and E .10 I started the car and it idled a little higher than usual. After driving for a few minutes, the car started ticking. Any hints on what I did wrong? The car had been cold for over 18 hours when I adjusted them.
Old 06-05-2004, 10:40 PM
mRek9R's Avatar
13ft-lbs for y7, 14ft-lbs for y8, intake: .007-.009in, exhaust: .009-.0011in. Oh btw honda motors are known for their slight knocking..it's normal..before i did my mini-me on my 45k y7 motor it slightly knocked also...8)
Old 06-05-2004, 11:04 PM
senpai's Avatar
Default Re: Torque specs for D16Y7 valve lash? (mRek9R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRek9R &raquo;</TD></TR><TR><TD CLASS="quote">13ft-lbs for y7, 14ft-lbs for y8, intake: .007-.009in, exhaust: .009-.0011in.)</TD></TR></TABLE>
Old 06-06-2004, 11:10 AM
Aquafina's Avatar
Default Re: Torque specs for D16Y7 valve lash? (maztur)
I'll try retorquing them to tha then. Before I adjusted them, it didn't tick like it does now.
I'm going to check the clearances again before I retorque them just to make sure they didn't turn while it was running.
If that doesn't work, I'll redo them in 3 hours or so.
Old 06-06-2004, 12:56 PM
Aquafina's Avatar
Edited first post
hagsmich
01-25-2018 07:29 PM
ExCon
07-19-2006 02:46 PM
BB6racer
01-19-2006 04:48 PM
94integrals
07-02-2004 11:28 AM
Quick Reply: Torque specs for D16Y7 valve lash?
