Tire question...
Tire question...
I have a 95 civic with 2.5/2.25 dropzones spring and I am thinking about getting 17"rims with 215/45 tires. Do you think that they will rub?
Re: Tire question... (vaggabon)
you will probably rub if your camber is set at 0 degrees.. probably would have to tuck it in a little (neg. camber) to clear the fender.
Re: Tire question... (DenMatic)
I dont even have a camber kit. I just put some washer in the back and left the front alone. So I can just leave the front the way it is then, eh?
thanks
thanks
you will rub going straight i have the problem with the 215 tire dependin if ur car is dumped alot. had to raise the car for a temp. solution until i figure out what to do. How much degree neg camber is good?
descartesfool
11
06-26-2004 09:55 PM
sackdz
21
10-01-2003 12:59 PM
