Tips for installing suspension components.
Hi. Soon, i will be installing a set of koni yellows, H&R sport springs, SPC front camber kit, and using the washer trick for the rear camber.
Should i use lubricant on the the spring perches to help keep squeking or other noises down? What kind of lube should i use? Also, what should i use on the bushings on the front upper control arms? Thanks a lot for your tips! I want to do things right the first time.
Solbros Owns Me
Re: Tips for installing suspension components. (import_racer_7)
I never use lube on my spring perches...but if you want, you could just throw on some Moly grease or even just some basic susension/bushing grease.
Same goes for the bushings...you can get general suspension bushing grease at any auto store...I usually use the stuff in a little jar
Black R
11
10-24-2005 11:52 AM
