Time to change the CAT? 170k miles, high HCs... opinions?
Old 03-31-2011, 04:15 PM
Juans_MX3's Avatar
Default Time to change the CAT? 170k miles, high HCs... opinions?
So my car is failing the high speed test for Hydro Carbons by about 20ppm (just barely failing) and its failing the idle test for HC by about 300ppm (standard is like 220ppm, my EX is putting out about 520).
Its passing CO% by about 50% on idle and high speed (really clean).
I am going to try running some 66k from Napa and high octane (91). Than refill it up 1/4 tank.
I got new plugs, wires, cap, rotor, PCV valve, timing (re-adjusted) and everything else.
Seeing how the car has 170k miles, I am really considering replacing the cat.
Should I buy a $400 OEM CAT or a aftermarket Magnaflow CAT?
I just want to pass emissions on this daily beast
Old 04-01-2011, 12:19 AM
ef_junky's Avatar
Default Re: Time to change the CAT? 170k miles, high HCs... opinions?
my opinion, unless your running boost or have a built N/A engine and need the higher flowing one i'd go with the oem replacement but thats just my 2 cents.
Ryank327
11-05-2007 08:38 AM
sicrx69
12
07-11-2007 03:36 PM
jchrm80
06-08-2007 07:35 AM
StrikerX
03-31-2005 06:58 AM
vtec.dc2
10-17-2004 03:45 PM
Quick Reply: Time to change the CAT? 170k miles, high HCs... opinions?
