Tilt steering wheel when there is none
My hatch never came with tilt steering but it seems that it is not quite at the top. The wheel blocks part of the speedometer/tach and this can get annoying.
I was wondering if this was the original position or if the previous owner lowered it a little? Is there any way to raise it to the top if it was never adjustable?
Re: Tilt steering wheel when there is none (MLogan)
I really doubt that anyone lowered the steering wheel positioin in your car.
I thought about doing it in mine but im a lazy ***. If they did lower it,
they would put some kind of washer on the 2 12mm screw posts. If you
cant figure it out let me know and I will explain it more in depth. If you want
to put a tilt wheel on your car I have 3 left for sale in the classifieds forum.
Re: Tilt steering wheel when there is none (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper »</TD></TR><TR><TD CLASS="quote">get a steering column from a dx, lx, ex, or si, and all your troubles will be over.</TD></TR></TABLE>
Yeah, do that! Buy one from me.
Re: (drunknbass)
what years stearing columns fit what? I thought 92-95 will not go with 96-00 and visa versa. I also though 2001+ will not mount to 00 and lower?
Re: (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass »</TD></TR><TR><TD CLASS="quote">im not sure. 97-2001 type r are the same tho</TD></TR></TABLE>
I know the eg6 colum will. Buy them from me!
Re: (d15dude)
well if the hubs are the same which everyone says they are. itll work. the bottom hub where it goes into the rack is the same as the side with the steering wheel. so it should work
Re: (drunknbass)
Tahts what I thought. So I could get a 1994 coumn mount it to my 96 wheel. and go on my way correct. if thats the case. this dude could get this guys CTR one and yank his?
I am I correct?
I am I correct?
Re: (B18C1 '96 Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 '96 Coupe »</TD></TR><TR><TD CLASS="quote">Tahts what I thought. So I could get a 1994 coumn mount it to my 96 wheel. and go on my way correct. if thats the case. this dude could get this guys CTR one and yank his?
I am I correct?</TD></TR></TABLE>
I dont understand what you said but:
92-95 have diff. steering wheels then the 96+. They do not mount the same.
96+ screw to the steering colum and 92-95 go on a post and screw to that.
no, you are not correct. 95 and 96 are totally different cars. 96 already has the tilt wheel, why do you need a different column?
1 Post
92 - 95 civics are the same as integra's
The ek is the odd ball out.
I 96 civic wheel will not bolt up to a 95. You would have to change to a 95 hub on the back of the wheel.
Re: (SpooN Man)
thats what I thought. But in essence you could use a 92-95 column and steering wheel and mount it in an EK. right?
SO in answer to this guys question you can put a tilt steering from an EK in his EG put you will have to use the EKS steering wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 '96 Coupe »</TD></TR><TR><TD CLASS="quote">my column is busted up. from when the car was stolen.
SO I could stick the 96 wheel onto the 95 column?</TD></TR></TABLE>
no, you can't. i already told you. 95 and 96 are completely different cars. 96-00 are different from 92-95. you have to find a steering column from a 96-00 civic.
Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">how hard is the installation</TD></TR></TABLE>
I just did this on my EG. It's actually pretty easy if you have a Helms. Should take an hour or two depending how fast you work.
Re: (ChiBoy)
ok... well i have a 94 cx hatch.... took the airbag steering wheel off.... would my colum from a 88 crx dx work? it has tilt wheel and the steering wheel teeth are the same... thats where i got my hub from? plus... the rex is wrecked chillen in the back yard. anybody know this.. lengths... mounting purposes... any wiring involved? thanks
Re: (ChiBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChiBoy »</TD></TR><TR><TD CLASS="quote">
I just did this on my EG. It's actually pretty easy if you have a Helms. Should take an hour or two depending how fast you work.</TD></TR></TABLE>
it took me and a friend about half an hour to take the steering column out of 2 00 si's, and put 1 back in. he had a theft recovery si that needed a new ignition, so we took the steering column out of a si he had for parts. you don't need a helms or anything, it's just common sense.
05civicdriver
Honda Civic (2001 - 2005)
13
04-13-2007 03:35 PM
b18cEK
03-23-2004 06:48 AM
