Ticking noise
Ticking noise
Theres this ticking noise comming from my 95 civic lx auto trans, i already did some maintenance like spark plugs, syn oil change, water pump, gasket valve cover with gromment seals, and timing belt and crank and cam seal front only, i have a guess that it could be just a needs a valve adjustment but not sure, to make it simpler it sounds like a mini diesel engine... thankss
Re: Ticking noise
Valvetrain noise (rocker arm assy, valve lash, ect.)
Injectors (wouldnt be consistent with your knocking description)
Exhaust leak, most likely cracked manifold.
Possibly compromised engine bearing/s in your short block assy.
A better description of the noise you are hearing will help others determine, I also see guys post up video/sound clips of the noise/problem. When the noise occurs most, what instigates the noise, and is it consistent with engine RPM, Engine load, ect?. And when did you first notice noise?
Paints a better picture.
For_Sale
07-12-2006 10:50 AM
