those of you who know anything about y7's.
im making a mini-me w/a 94 z6 head and tranny on a 97 y7 and my chilton book said that on the gear that is located behind the crank pulley, that there is sposed to be a washer on each side of the gear. is this correct, b/c mine only has one washer and it was on the inside of the gear.
also, should i replace the oil pump since ive got it out and everything? the block has 108k on it and we've replaced everything else on it.
senior gold member
Re: those of you who know anything about y7's. (JasonBlackEJ1)
I know on bseries theres 2. I don't if that helps you any but I would think it should have 2 too since it kinda holds in the timing belt in there.
I don't believe there is. I changed my crank pulley from my Y7 to my Y8 and I do not remember multiple washers.
Re: those of you who know anything about y7's. (civic-4-ges)
well, i found out today that there is sposed to be 2. they keep the timing belt from slipping.
i'd change the oil pump.
Especially since your not going to drive easy on that VTEC engine
smallttocs
02-05-2012 11:37 PM
