for those who did teg dash into eg, help on heater box???
im doing the teg dash into eg but having some problems getting the civic heater box out... i got the fan part out but the middle piece is a pain in the @ss to get off... it looks like there two hoes on the bottom... do i need to take those off first??? and when i get the teg heater box this will bolt right up right??? and everything will be plug in play cause i was having some trouble making the teg dash fit with just he middle of the civic heater box in... it was off like half an inche.. and for wiring did u guys have an extra plug where the cluster is... cause on the teg wiring harness theres three blue plugs and in the instructions it only had the 16 pin plug and 13 pin plug and there was a 10 blue pin plug... or is it because i got it off an auto??? its got alot of green coloered wires... please help me thanks
Re: for those who did teg dash into eg, help on heater box??? (ek9hatch)
i have no idea about the heater box or anything.. i never did the swap but have read about, wanted to do it at once and then decided not to do it cause it requires to much and does not look the best w/ cutting the door panels on the civic doors.. good luck tho..
i do know that the 10 plug harness u got extra is because its from a auto.. i have swapped my civic stock gauge cluster out for an integra gsr cluster and noticed that harness on the back of the cluster..
Re: for those who did teg dash into eg, help on heater box??? (95CivicEX)
o ok thanks... but has anyone else taken there heater box out before???
motoxx644
06-09-2008 12:27 PM
ecksman
04-02-2004 07:42 PM
Dancing is Forbidden
10-04-2003 09:56 AM
