Thinking about JDM B16a Swap into 93 Civic hatch - OBD and CA emissions questions
So ive been contemplating wat kind of engine to get , i was looking at the b16a jdm http://hmotorsonline.com/shop/sc2000...age&item=30005
but dont really know if its obd1 ? also since i live in the lame state of cali i wanna get a bar'd does anybody know wat i will be needing the engine is going into a 93 si hatch,
Anyone?
Anyone?
Re: B16a Swap
you can't bar a JDM B16 in your civic. You have to get a USDM B16, either the B16A3 from an Obd1 Del Sol or the Obd2 B16A2 from the 96-97 Del Sol or 99-00 Civic SI. Me and my buddy just talked to the smog ref last week. We are in the inland empire area of so cal by the way, and he says, he will not pass a JDM motor what so ever. They are higher compression motors and he doesn't care if they have all the smog equipment on it. He will not visually pass it.
Best bet for you, is contact your local Ref Station, and ask him what your options are. And go from there. Cause from what I've seen on HT, alot of the ref's are different. Hope this helps.
Re: B16a Swap
Idk about that man ? up here in nor cal its diffrent i guess, my freind got his h22 bard jus changed the ecu and intake mani to a usdm and got it passed , i was also ther wen the reff bard a b18c so its probably diffrent down ther.
Re: B16a Swap
Yes indeed i knew you could just double chekin about it ! Yeah i called them up they have Obd1 this should be good start to a project ! Do you know wat Ecu is the is usdm one for b16?
Re: B16a Swap
Just some heads up, make sure you get a brand new Oem CAT and O2 sensor. And if your going aftermarket on headers or intake, make sure you have CARB numbers visible.
GDD Black Reject
Re: B16a Swap
Buy a Skunk2 IM ... with CARB sticker ur straight .... or just look at my build thread.. u can use a GSR harness u just have to tuck like 3 plugs.. P30 Ecu is hard to find for me right now ... but ya. i got my motor from HMO and they are a big help with this. just tell them what car u got and what engine u wanna put in ..
Re: Thinking about JDM B16a Swap into 93 Civic hatch - OBD and CA emissions questions
Wer would i make a posting to find Ecu im sorta new to this ? do you know of any site to buy usdm motors, i really Have Max hate for California smog
GDD Black Reject
just buy from Hmotors. then get a Skunk2 IM which is like $200 change sparkplugs/wires make sure u check ur dizzy. then borrow a P30 ECU from someone ... go get it smog. u wont past the first time.
yeah My buddys got a p30 ecu, why wont it past the first time? hopefully i get it bard soon cuz i know the ref and he said he doesnt know for how much longer ther gonna let jdm engies bar
I am going through this dilemma as well. I might register my car in Nevada to avoid all this headache.
I'm looking at the same swap or a b20 swap..best bet is to check regulations in the state before you even decide on the swap. I went through the same issue in florida looking to see what they will take and what they wont.
hondacivic90zc
14
03-10-2007 12:03 AM
