Are these rods still useable...rusty
Re: Are these rods still useable...rusty (crimsonv4mpire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonv4mpire »</TD></TR><TR><TD CLASS="quote">sand blaster.</TD></TR></TABLE>
Should be able to take it right off, although that one that you took a close up look on looks pretty bad you might need to sand blast then shot peen it as well.
Now that i looked closer those are just stock rods anyway. What i would do is take those pistons and put them on your rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonv4mpire »</TD></TR><TR><TD CLASS="quote">sand blaster.</TD></TR></TABLE> x2
Re: Are these rods still useable...rusty (Luserkid)
2 options;
if you just need a set of working rods for the daily beater (BEATER, as in 200k and still goin)
if you plan on doing any performance mods later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Now that i looked closer those are just stock rods anyway. What i would do is take those pistons and put them on your rods. </TD></TR></TABLE>
I vote option #2
I vote option #2
Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">How do I know which rods these are. they are civic type r pistons...so they are type r rods as well? </TD></TR></TABLE>
See this picture:
On the left rod you could see some markings that come out PR3 which is a B16 rod. P73 is i believe Type R rods, PR4 is LS/B20, P72 - GSR. Look at all the rods and see whats stamped on.
See this picture:
Re: (Luserkid)
Try putting them in some coke for a bit... its only surface rust they should clean up nice. You may want to use some steel wool too.
Once you've cleaned the coke off put some oil or another corrosion inhibitor on them if your not going to use them right away.
1 Post
Re: Are these rods still useable...rusty (lil vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil vin »</TD></TR><TR><TD CLASS="quote">just buy new ones </TD></TR></TABLE>
Why?
Use a die grinder and a Roloc to clean the rust off. It will take all of two minutes.
Why?
I agree, clean them don't ditch them. Soak them with some rust penetrant such as PB Blaster or WD40. Let them soak for a bit then hit them with some steel wool. Next clean them & oil them up like a couple of stripppers on a slip & slide....you get the point
SilverWarrior
08-24-2008 08:38 PM
phantomeg6
48
04-29-2007 05:07 PM
