Are there any bolts I shouldn't use anti-seize on?
I recently took out my D15Y8 and pretty much wire wheeled and anti-seized every bolt still in the engine bay. I also did the same to most of the front suspension bolts while installing ES bushings. My car was sitting for a few years and most of the bolts were rusted. I hate when ANYTHING is wrong with my car and I feel the need to make sure everything is right. Is there any (external) bolts that should not be anti-seized? Thanks
Re: Are there any bolts I shouldn't use anti-seize on? (fizix_skate)
Never hurts to have anti seize on bolts. Things like flywheel/pressure plate i wouldnt becasue there suppose to go on dry. Other then that you should be fine.
