teg sportlines on 5th gen civic
New User
i've got a 94 civic coupe and was wondering if eibach sportlines meant for a 94-01 teg will fit just the same. is the only difference the spring rate itself? any help would be greatly appreciated. thanks guys.
CHRIS
CHRIS
Re: teg sportlines on 5th gen civic (deviant94ex)
yeah they fit fine. I'm running teg sportlines in the back of my 93. they are a diff't part # so I assume a diff't spring rate, also noticed that the rear teg sportlines had one extra coil compared to the civic ones, I assume a higher spring rate, but have been unable to find what they are.
the only reason I did this was because my civic sportlines seemed to lower more in the back for some reason. I think it is just a difference in the wheelwell size that made the back wheel appear to fill up the well as opposed to the front wheels, dunno...
New User
Re: teg sportlines on 5th gen civic (mps9506)
ok....so they fit fine....but do they actually sit a bit higher than sportlines made for the civic would. its not too big of a deal but i was just kinda curious. i will probably be runngin koni yellows anyways and be able to set them at a different perch settign to compensate. thanks
CHRIS
CHRIS
I have a 93 cx hatch with a b18c1 swap. I installed Neuspeed integra race springs .It does sit 1/4 to 1/2 inch higher than my brothers 93 SI hatch with civic race springs and b18c1 also. The teg springs allow for the heavier integra body.
New User
Re: teg sportlines on 5th gen civic (joe-1)
thanks for the replies......i am going with the koni yellow shocks so that i can use the adjustable spring perches as well to lower the car to the height that normal civic sportlines would give me. i will be running 16" black slipstreams with some sort of 205/45 tire so i think that this set-up will be just about right. also, any of you guys know where i can get a set of strong flat black lugs for the slipstreams. thanks for all of your help....this board is great!
CHRIS
CHRIS
tanjulio
12-01-2002 04:47 PM
