taking out a single cam.
I just blew my tranny in my single cam dont ask how, i just need some advice on how to take the hole motor and tranny out like what do i need to do to get it out i have all tools and a cherry picker to lift out. a little more info on the car its a 98 ek hatch with a y7 in it any info or pics on it is help full since never done befor.
Re: taking out a single cam.
Ive took out my engine 4 times now, takes me about an hour to and hour and a half now to have the engine completly out. No power tools. just drain all your fluids, except oil, unless you want to, disconnect all hoses, then any vaccume lines, throttle cable, ground wires, wire harness, fuel line, etc, then unbolt ur lower ball joints and pull them axels out, easiest with a fork. Attach ur cherry picker, and unbolt ur mounts. BAM ur done
well the first three gears are going out realy bad and the clutch just went out, but thanks for all the help regarding taking it and yeah my neighbor is a mechanic so he as a cherry picker and all the sockets to take the axels off and he has an impact gun that i can use, i had one other question do you have to take like the front suspension of for the axels or what.
You can just drop the motor out the bottom, don't even need a cherry picker. Drain your fluids, take pics of where vacuum hoses go, unplug harness, pop out axles, attach cherry picker, undo mounts. Not that difficult
Jack up the balljoint, put a breaker bar or lug nut between that and the LCA and lower the jack. It should pop out, if not try it again. You don't need a pickle fork to separate the ball joint
no dont use the fork
just PB blast it and let it sit and then use a breaker bar or put the nut back on some and hit the sides of it to break it lose (this is what i did) and it worked
the fork will only break your lower balljoint and you will have to get a new one
This all help a hole lot hopefully get this god forsakin single cam out this weekend.
I have a ek cf duckbill mugen style front lip and eg driver seat for sale or trade to i need a tranny and clutch for a single unless some one wants to trade a whole swap.
318 Curves, 11 miles
see swapthread in my sig for basic guidelines on removing a singlecam. Honestly ain't too hard though.... you just keep unbolting stuff until it practically jumps out at you.
If you brought in the LCA and knuckle connected with a ball joint, would they honor the warranty on lifetime warranty balljoints?
can i get a little bit more indepth help on taking the balljoint crap off for the axels im just about to this point in the removale of my single cam and realy dont want to f@%k things up so if any one can explain it a little more this is first time iv done it and if any one has a y7 or y8 with tranny for sell let me know!
either get a ball joint removal tool (reccomend this) or there is another way, i think its in the faq up top.
or just beat the **** out of the control arm, be careful not to hit ball joint.
so do you remove the pin out from below the ball joint then what im a little lost like step by step what do you do or when i get to it will it make more sence cause from looking at pics i realy dont understand it lol.
