Tach Install
Tach Install
So i tried to install my tach today with some friends, and there r 4 wires from the tach, Red, Green, Yellow, and Black. Green goes to the tach, Black is the ground, and Red is ignition and yellow is power, but when we did it Red was the power, when we put the red wire from the tach to a battery wire it worked, and we dont kno what the yellow does, dose any one kno what to do, and i need a diagram for the fuses, so we need some help
peace, thanks
peace, thanks
Re: Tach Install (XpodX)
im pretty sure its the power for the light...o and btw, what kind of car did u put it in and where on the distributer (if u did attach it here) did u hook it up to (color of wire?)
[Modified by CrOmEdOmEcHaMbEr, 2:59 PM 8/4/2002]
we can get it to work but it never turns off? i really have no idea what to do
Re: Tach Install (mr. skelly)
It needs two power sources becuase one is for the lights and one is for the tach power. So you can hook into your cigarette lighter for main power and then hook into a switched dash light for the other power. I used the light that was right above my lighter. It should then work.
My lighter isn't live all the time. It shuts off when I turn off the car. You need to find power that is controled by your ignition switch. That way the tach wont be on all the time.
Re: Tach Install (yuckymucky)
just plug it into your fuse box....for the tach power, plug it into the radio fuse. for the lights for the tach, plug that wire into the intrument lights fuse.
purple98ek
06-06-2005 07:57 PM
