tach help! please help if you have any knowledge on tachometers for 96-00 ek.(dx,cx)
alright, i bought a tach from autozone, because my car is a CX and doesnt come with a tach. my brother mounted it and did everything for me. we started it up the light worked and everything. the tach was way off at first and he messed with it a little til it worked, but it was idling at 2100 rpm( i think it is wrong) my car has no problems at all, so its not my car. i went to start it up the next day and everything worked except for the tach rpm reading. it was idling below the 0 and wen i revved it, it went backwards. so my brother disconnected the green wire and now he's being a giant deusche so im doing it myself. please share all info you have or any past expieriences.
were wut wire do i tap into and how exactly do i do it.
thank you, please explain in detail not good with electrical at all.
Re: tach help! please help if you have any knowledge on tachometers for 96-00 ek.(dx,cx) (96hatchy)
tap it into the blue wire on the harness.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">How much did that spiffy little thing cost?</TD></TR></TABLE>
30$,but free for me. i know its gay but i dont want a ginormous tach
ohhh yea, which blue wire
There may be/should be a small switch on the back of the tachometer that allows you to select how many cylinders the engine has.
Make sure that it is set to "4".
Re: (VegaS10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatchy »</TD></TR><TR><TD CLASS="quote">
ohhh yea, which blue wire.</TD></TR></TABLE>
the solid blue wire in your last pic.
Re: (EK tommy)
isnt there a wire you can hook it up to on the harness that plugs into the cluster? and then theres a single wire on the driver side of the engine bay closeer to the firewall you can hook it up to
and lastly... why didnt you just buy a ex/hx/lx cluster? try and return that and ill sell you an ex cluster
Re: (96hatchy)
.</TD></TR></TABLE>
Top right corner of your dizzy plug.
.</TD></TR></TABLE>
Re: (FullRaceHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceHonda »</TD></TR><TR><TD CLASS="quote">
and lastly... why didnt you just buy a ex/hx/lx cluster? try and return that and ill sell you an ex cluster </TD></TR></TABLE>
Wouldn't be very smart considering he got it for free. I highly doubt you'll sell him an EX cluster for cheaper than that...
Re: (FullRaceHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceHonda »</TD></TR><TR><TD CLASS="quote">isnt there a wire you can hook it up to on the harness that plugs into the cluster? and then theres a single wire on the driver side of the engine bay closeer to the firewall you can hook it up to
how much, last time someone said they would sell me an EX cluster they never responded and i had the money and everything, how many miles does it have on it? im also not sure b/c my car is only 117,000 miles and if i decide to sell the car they might not believe me about the actuall miles. but yea hit me up with some pics, i got money.
Re: (96hatchy)
there should be a sender wire near the fire wall on the driver's side that is blue connected to a harness with a black rubber cover
check out: http://www.hoon.tk/tech_tips/tacho.html
2nd to last pic
2nd to last pic
Re: (EK tommy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK tommy »</TD></TR><TR><TD CLASS="quote">the solid blue wire in your last pic. </TD></TR></TABLE>
and please don't use that ghetto *** wire clamp they usually give you in those cheap tach kits... they blow and hardly ever work... do it right
Re: (94c1v1cex)
my neigbore said some **** about the grounding wire and some other wire being reversed or something, anyone know wut hes talkin about
Re: Re: (EK9Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9Rider »</TD></TR><TR><TD CLASS="quote">go to a junk yard and pick up a cluster with tach....
that tach you have one there = rice
no need for rice.... </TD></TR></TABLE>
i know, its not really rice, at least its not a huge 5 inch tach w/ a huge *** shiftlight. the reason i got mine is because its subtle and small.
Just in case you might have the same problem I incountered the tach might have a small switch on the back to select what cycle motor 4,6, 8. If its wrong you get wrong reading. I had it right but bumped it somehow and eventually figured it out.
Nice green wire I used the same shizz from Kragen ha ha.
Also you don't have to connect the RPM wire to the Dizzy Their is a blue wire on the harness at the right of the hole on ur firewall. Regardless if your car comes with a tach or not you should still have a RPM signal blue wire on the harness. If I have time I'll take a pic and post it.
PEACE
PEACE
i have a gauge cluster from a 99 si if you want it. plug and play!
Re: tach help! please help if you have any knowledge on tachometers for 96-00 ek.(dx,cx) (Wonk Unit)
everyone tells me they have a guage cluster but wants too much 4 them.
