switching to synthetic this late?
Hey guys i get free castrol syntec at my work and i was wondering if i should switch my car to it? It has almost 200,000km's and i believe its been running on conventional or at least since ive had it but do u think it would be okay to switch over?
Cool Cool Island Breezes. BOY-EE
Re: switching to synthetic this late?
Throw some synthetic in there. If it burns it, throw some regular in it next time.
My EM1 burned synthetic. It doesn't burn regular. I tried synthetic once or twice. Now it's just on regular.
It's not rocket surgery or brain science. Just pour the **** in there and see what happens.
Hell yeah do it. I have never had a problem with burning synthetic. I always run synthetic, in every car as soon as possible. Especially if you get it free.... are you kidding me? Of course you should lol. Change it out at 2000 miles and keep your internals sparkling.
2000 miles?! Why? What's with everyone obsessing over oil?
I track my S2000 and I change it either every 3k or every 2-4 track events. The 2 -4track events usually come first....
My EM is my DD and it gets oil changes with reuglar *** oil every 3-5k miles. it has 133k on it and it runs great.
Keep your internals sparkling? for...what...??
I wouldn't use it, but that's just me. I would stick with conventional and change it regularly. Give it to someone who uses synthetic in their vehicle.
if you have been running regular all this time, take advantage of the free synth and change it at 500 miles twice to fully get rid of the regular, or do an engine flush with some diesel. PM me if you wanna know more info.
its not healthy for the motor to suddenly see a different type of oil, one is thick at start up and takes a bit to thin out, the other is thin after only a minute or so of operation
You don't need to do any of that. You're not going to hurt the motor's feelings. Engines don't get "used to" things like that.
It will probably burn more synthetic. But it depends...who knows. Just pour the damn bottle in there and see what happens.
engines do get used to stuff like that. different oil has different thickness, and running with a mix (drain only gets like 40% of the oil) isnt that great of an idea. thats why I say 500 miles, plenty of time for the new oil to mix and clean a bit, next oil change, should be closer to full synthetic in the motor.
THESE ARE MY RULES, so dont think its by the book. its a method I have used, because I am extremely **** about my motor and do the best for it to keep it clean and running.
the diesel is an awesome cleaner. you fill it via the oil cap hole, top it off to the oil cap hole. let it sit for at least 24 hours. clear diesel in, after sitting, coffee comes out. refill and let sit another 24 hours, nearly clean.
I did this on a friends car, it had 80k miles, and the diesel didnt come out clean the first time, and his car was always serviced correctly by a dealership since the day it rolled off the dealer lot. its much safer then seafoam, which is a bit too strong.
You have a D series. You probably spend more time and effort cleaning it and spend more money on oil than the engine is worth.
Benefit vs. Cost/effort, my friend.
I'm NOT that **** about my engines. My GSR had 158k miles on it and still ran like showroom fresh. It even did 130mph and got 30mpg on the same tank once. My Si has 133k miles on it and runs great. No oil burn.
Again. Cost/effort vs. Benefit.
why does the engine matter? if I owned a 3 cylinder geo, id treat it the same way. a car's a car. treat it well, maintain it, keep it clean, keep the carbon **** out, and the motor is guarenteed for a very long time. plus Im rather fond of the single slammers lol, easy to work on. ever done valve seals and guides on a B series? yeah, go for the D's lol
The type of engine matters because sometimes for the extra cost of synthetic oil over the life span of the engine, you could have just paid yourself for a fresh engine and used regular *** oil.
I was always told that synthetic holds materials in suspension better than regular. That's one of the benefits of synthetic.
I used it in my SR20DET because it ran very hot and it was very abused (by me) and a couple of my B series cars (there's that abuse again). I use it now in my F20C since I track (abuse) the car very often.
I'm talking abuse as in recreational use...not just retarded abuse like throwing pennies and rocks and a bottle of coke and a half quart of oil in an intake manifold...which I have also done...err...not to my car...err...or an engine that was going to be in a car for more than a day longer.
Comptech98GSR
02-08-2003 02:39 PM
