sway bar on a 00si
sway bar on a 00si
ok, i did my search and it just confused the hell out of me. will an itr sway bar just replace my existing sway bar?? if anything, i am guessing i just need reinforcements right??? well i looked on the beaks website and it is like $60. where is everybody getting them for $20 at?? also i now that a usdm itr is 22mm and an jdm itr is 23mm. is there really any difference and what about a bigger bar. i heard ground control made one that is 25-26mm and what about a 24mm if anyone makes one. what do i need for an upgrade on my sway bar. will the existing endlinks work?? any help would be appreciated
Re: sway bar on a 00si (2000si)
Yes ITR bar will replace your exsiting bar. Pretty sure you can use the stock endlinks for both.
I have a Skunk2 sway bar, and I like it. Comes with all the necessary hardware to mount it, including endlinks. It's only 21mm, but not such a huge deal vs. 22mm USDM ITR and 23mm JDM ITR.
Good luck man.
Good luck man.
Re: sway bar on a 00si (EpDarks)
yes it will fit. you may have to run a beaks kit. it may not be necessary but i would get it anyway. you reuse your end links
Re: sway bar on a 00si (snail)
so all i got to get is the bar then. also where do i get some reinforcements from. the beaks ones are like $60. are there any out there that are less expensive but perform just as good a job. i kept reading about everyone getting some for $20. where??????
Re: sway bar on a 00si (Bagel Williams)
edit- nevermind.
[Modified by Paranoid Android, 8:25 PM 12/8/2002]
BLUE EH3
13
06-08-2005 06:18 PM
nuspeed27
09-18-2002 11:01 AM
