Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ?
Im swapping out the entire rear suspension. trailer arms, rotors, calipers, rear lower control arms, etc, etc.
Will everything fit normally ? just want to make sure because I dont want to leave my car on jackstands because something didnt fit
Re: (zer0_2_6ixty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0_2_6ixty »</TD></TR><TR><TD CLASS="quote">it will work,i am doing a complete GSR front and rear disk brake swap very soon.</TD></TR></TABLE>
true i am gonna do the same
You need the brake booster + master and proportioning valve off the GSR, Their is a swap guide on the hybrid garage forum or hasport forum.
Good luck.
Good luck.
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (93EH6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 »</TD></TR><TR><TD CLASS="quote">will it work the same using del sol parts cause i totaled my sol and picked up a cx hatch and wanted rear discs so will it all work fine</TD></TR></TABLE>
Yes it will work. Come on people learn to use the SEARCH function, there is an end all brake swap thread that Drag made up a long time ago.
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (ill phil)
Yes it will all work. You can use 94+ teg brakes, 99+ SI brakes, Del Sol rear discs, 91-93 teg rear discs etc. There are a few different ways of doing so, and if you do a search under my username it will pull up a how to including all tools needed and step by step with pictures on how to do the swap while still retaining your factory trailing arms. Good luck and IM me if you have any questions. And BTW, you DO NOT have to run the teg M/C and Prop valve, but it does help in braking if you happen to run across one for a good deal. I believe the one swaps right over, but the GSR won't due to the ABS and the way the lines run. Tom (b18c5-eh2) did a great write up a while ago pertaining to which master cylinders and prop valves were the best and most cost efficient for each application. Good luck.
Brandon
Brandon
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (celph.)
If you're using 94+ teg parts, it's all bolt in. I did mine and had no problems with anything fitting. The only think that was tricky was bending a new line for the MC. But you may not have to do that if you get the right one.
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (ChiBoy)
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=694565</TD></TR></TABLE>
y'd u post that?
y'd u post that?
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (stock93cx)
yeah everything works fine
i did mine and its great i just need better tires now to use all my braking power
I think he posted this cause it seems as him and Billy Blue Hatch got scammed by this guy.
Re: Swapping out my 93 CX rear drums for GSR rear disks, will everything fit normally ? (Billy Blue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Billy Blue Hatch »</TD></TR><TR><TD CLASS="quote">I NEED A TRACKING NUMBER</TD></TR></TABLE>
HAHAHA, im sorry that was too funny!! So random! is this the guy that ripped u off?
beedoublejay
10-15-2004 07:36 AM
Chickenball
25
05-15-2004 05:02 PM
92eg6
04-08-2004 10:25 AM
