Swapping Civic Si/CTR LCAs and forks: Will they change camber?
I am thinking about upgrading my Civic EX front LCAs and forks to those of a 99-00 Civic Si or CTR (same thing). Would swapping LCAs and forks change camber, or would camber not be affected? Would anything (camber, caster, toe) be affected?
Re: Swapping Civic Si/CTR LCAs and forks: Will they change camber? (EricUSC)
Nothing should be affected, but don't forget that you can't use your EX swaybar on the SI LCA's.
I would still get an alignment though.
Re: Swapping Civic Si/CTR LCAs and forks: Will they change camber? (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">Well if it's not going to change "anything" then what will geting an alignment do?</TD></TR></TABLE>
Then don't do it if YOU dont think you need it.
going to SI lcas wont change your camber 1 degree either direction, but due to manufacturing tolerances, your toe could be off enough to cause premature tire wear.
Re: Swapping Civic Si/CTR LCAs and forks: Will they change camber? (tonyXcom)
And I've learned that Toe causes tire wear, and Camber just shows where the tire will wear.
Re: Swapping Civic Si/CTR LCAs and forks: Will they change camber? (Eddie HatchBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddie HatchBlack »</TD></TR><TR><TD CLASS="quote">And I've learned that Toe causes tire wear, and Camber just shows where the tire will wear.</TD></TR></TABLE>
