swap questions??? need help
im swapping a gsr motor into my civic lx... will i be able to use the same civic lx wire harness or do i need the gsr wire harness???
when i dropped in the motor i have a big gap between my exhaust and my header.. is it suppose to have that gap??? what can i do about that???
Little Hercules
Re: swap questions??? need help (epak)
you will need the GSR wiring harness and the ECU. the gap will be there. you will need to get a test pipe or go to your welder and have him fab up some extenions on the cat since he wont do a test pipe. unless you nkow hime
Little Hercules
a civic test pipe for your GSR swapped hatch?? hmm..i dont think so. if it does one of your flanges will need to cut off and re-welded back on to match up with the flange on the b-pipe
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epak »</TD></TR><TR><TD CLASS="quote">im swapping a gsr motor into my civic lx... will i be able to use the same civic lx wire harness or do i need the gsr wire harness???
when i dropped in the motor i have a big gap between my exhaust and my header.. is it suppose to have that gap??? what can i do about that???</TD></TR></TABLE>
i have found it is easiest to use the harness from the car.
Little Hercules
Re: swap questions??? need help (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
i have found it is easiest to use the harness from the car.</TD></TR></TABLE>
HAHAH i thought the same thing. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epak »</TD></TR><TR><TD CLASS="quote">so the omni power test pipe will match up with both ends and fit perfectly??</TD></TR></TABLE>
i dont think your gonna be able to afford an omni power test pipe if you baught a test pipe off egay for a civic. but it would if you had an exhaust made for you gsr swapped hatch.
Little Hercules
Re: swap questions??? need help (thacivicguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">thats awesome i made it into your signature</TD></TR></TABLE>
that guy was stupid. haha your reply was classic so i had to!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thacivicguy »</TD></TR><TR><TD CLASS="quote">we did that with a b16 header and it worked</TD></TR></TABLE>
from my experience it didnt but i think thats because i have a cust 3.5in downpipe and exhaust
